Electrical problem
1997 Dodge Dakota V8 Four Wheel Drive Automatic
What is the best way to change out the fog lamp assembly?
Monday, May 3rd, 2010 AT 7:35 PM
MECHANIC
THe bulbs are replaceable. Access them from under the front of the truck.
SPONSORED LINKS
Sunday, May 9th, 2010 AT 5:11 PM
MECHANIC
I'm sorry. Are you replacing the entire assembly or just the bulb? If it is the assembly, there are two bolts that hold the OEM assembly in place. Do you plan to replace them with the OEM type?
Monday, May 10th, 2010 AT 9:18 PM
EVEN
MEMBER
It is OEM used part. Just want to know what is the best way to access it. Looks like I might need to remove the wheel well mud guard. Just looking for a suggestiion. Laying on my back and reaching up in is not great access.
Monday, May 10th, 2010 AT 9:45 PM
MECHANIC
Honestly, that is the only way. There are only two bolts that hold it in place. Honestly, I wish there was an easier way.
