1996 Dodge Dakota engine floods/quits when turning right or
MIKE MORSE
  • 1996 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 140,000 MILES
This trucks engine runs great, starts great untile I make full right hand turns, at which time the engine shuts down in an instant. If I pop the clutch while still rolling, and reve the engine a little it comes right back. If it stalls to a stop, it is very slow to re-start.I sometimes have to wait for more than a few minutes before it will re-start. If I hold the gas peddle to the floor and crank it for 20 or so seconds it will often start.
Thursday, February 11th, 2010 AT 10:52 AM
  • 109,901 POSTS
Have you checked for trouble codes? I believe in 96 you can do it at home. Try this and let me know if it works:
Cycle the ignition key from of to the run position 3 times. The 3rd time let it in the run position. THe engine light will begin to flash. You need to count the number of times it flashes. Each code will be a 2 digit number. The light will flash, have a slight pause, flash again, then have a longer pause. It will then continue on if there are more. The last code will be a 55 indicating it has finished.
Let me know what codes you get. Remember, you don't turn the key to the start position, only the run position while cycling.
Saturday, February 13th, 2010 AT 1:49 PM
