1995 Dodge Dakota Gas Problem
HOBDEY85
Engine Performance problem
1995 Dodge Dakota 6 cyl Four Wheel Drive Automatic
Almost two years ago my truck begin to slow down to about twenty miles an hour when it got below about a half tank of gas. The RPM is extremely low and the pedal can be held to the floor. It continues to drive but it does not reach a drivable speed (espcially on highways). If I put just a gallon of gas in it, it drives fine...but once it reaches that halfway mark it slows down again. It doesn't seem like it would be a fuel filter problem because it sits in the bottom of the fuel tank so it is always surrounded by gas (since it is still half full). The fuel pump still works after two years so I don't think that is the problem either. Please help...
Jun 3, 2009 at 1:37 PM
BMRFIXIT
  • 19,053 POSTS
Begin basic diagnosis of fuel system by determining fuel system pressure .
Remove fuel rail test port protective cap. Connect a fuel pressure gauge with a minimum 60-psi (414-kPa) capacity to fuel rail test port. Test port is located at rear of engine. Start engine and allow to idle. If pressure is more than 45 psi (310 kPa), fuel pump is okay.
When at ½ and you fill up the tank how many gallons does it take
also you may have a bad float giving you the wrong readings
good luck
Jun 3, 2009 at 11:01 PM
