1994 Dodge Dakota Heater Blow Motor
1994 DODGE DAKOTA
250,000 MILES • 6 CYL • 2WD • MANUAL
RTUBWELL
The heater blow motor will not turn on. Have already checked to fuses in the regular box under dash and the fuses in the relay box under the hood. Also have checked the motor on direct hookup. It comes on direct hookup. Somthing is stopping the motion from getting the proper power. Is there another relay fuse or switch other then those mentioned here?
Oct 2, 2010 at 8:47 AM
  • 110,244 POSTS
Under the hood, passanger side, you will see a wiring harness plugging into the firewall about 6 inches from the top of the firewall. That is attached to the blower motor resister. Check the plug for evidence of it melting. If it looks good, unplug the harness and you will see the blower motor resister. It is held on by two small bolts. Remove it and replace it with a new one. They are cheap. Chances are that is the problem.
Let me know if you have other questions and if it helps.
Oct 3, 2010 at 8:10 AM
