1993 Dodge Dakota trans leak
119,999 MILES • 6 CYL • 2WD • AUTOMATIC
TABORLEE
I have a 93 dakota it has a auto trans in it. I just recently bought it. The guy who sold it said it has a junk yard trans in it. It shifts fine just leak out of the front of the trany i have no clue what it could be What are the options at this point . My dad thinks its a seal . Any help is awesome thanks
Apr 7, 2009 at 4:03 PM
CARADIODOC
  • 34,412 POSTS
Leaking in the front could be a front pump seal. Very inexpensive part but the transmission must be removed to replace it. Typically, the rubber gets hard with age and heat. It rarely causes a problem until someone removes the engine or the transmission. The heavy torque converter drops a little if it's not supported and cracks the hardened seal.
There is also a vent in the area of the front seal. Fluid will foam out of the vent if it is over-filled.
caradiodoc
Apr 9, 2009 at 11:10 PM
