1993 Dodge Dakota Strong Trans Just Quits pours fluid
PASTORKEV316
  • 1993 DODGE DAKOTA
  • V8
  • 160,000 MILES
This Auto Trans is on a 318 v8. It is strong and will pull and shift fine for about a minute but it just quits all of a sudden and has begun to pour fluid out of the bell housing. I bought it this way from young man who clobbered a ditch in an ice storm. He fixed the radiator and three days later the tranny went. I can brake tork it in reverse and drive and drive it around the parking lot. Just before it dumps the fluid it makes a noise. Can someone offer some insight. Time to replace or fixable? Thanks.
Monday, April 26th, 2010 AT 4:39 PM
  • 109,885 POSTS
It sounds like the torque converter is loose or damaged allowing fluid to come out the front seal. I would recommend removing the trans to check where the problem is coming from.
Tuesday, April 27th, 2010 AT 1:03 PM
PASTORKEV316
  • 7 POSTS
That is what I am hoping for. The truck had been wrecked and went nose down into a ditch skidding over several rocks. Thanks.
Tuesday, April 27th, 2010 AT 7:36 PM
  • 109,885 POSTS
Glad to help. Honestly, the only things there are the torque converter which goes through the front seal. Of course, the front pump is there and could be damaged, but at most you would need to remove it replace the O-ring and rebolt it. If you find it is damaged, take all the bolts out and you will need what is called a slide hammar to pull it away from the transmission.
Let me know what you find or if you have other questions. I'm anxious to hear what the problem is.
Tuesday, April 27th, 2010 AT 9:48 PM
PASTORKEV316
  • 7 POSTS
I pulled the Pan and found a few chunks of metal so I am saving up for a rebuild and new torque converter.
Saturday, June 12th, 2010 AT 4:38 PM
  • 109,885 POSTS
How big were they?
Monday, June 14th, 2010 AT 12:52 AM
PASTORKEV316
  • 7 POSTS
If I remember correctly there were 4-5 about the size of a pencil lead. I mainly just want to know I can trust the truck.
Monday, June 14th, 2010 AT 10:58 AM
PASTORKEV316
  • 7 POSTS
Do you know how I can identify what transmission it is that I have. This truck is a 93 and I also have a 91 Dakota 4x4 6 cyl. 45RE/RH but I don't know how to tell which of the many different types it is. Thanks
Monday, June 14th, 2010 AT 11:02 AM
  • 109,885 POSTS
The trans pan is different from one to the other.
Monday, June 14th, 2010 AT 1:39 PM
BAMACAMP24
  • 8 POSTS
If it is a 14 bolt pan it is an a500/42re and you can get the tork converter from a salvage yard perty cheap
Sunday, July 3rd, 2011 AT 3:19 AM
  • 109,885 POSTS
It could be one of 5 different transmissions. I need to see the shape of the pan. Also, if you can, get a new converter. If you can't, you should be able to find one in a salvage yard. Just make sure where it goes into the front seal is in good condition and not scored from the old seal and it comes with a warranty.
Sunday, July 3rd, 2011 AT 4:53 AM
