1992 Dodge Dakota starter
185,000 MILES • 6 CYL • 4WD • MANUAL
LILMONTANAGAL2000
how do I change the starter on my dakota? how many bolts are there?
Sep 2, 2008 at 1:29 PM
  • 110,251 POSTS
Hi:
Replacing the starter on a dakota will require patiences. Only two bolts hold the starter on, but getting to them is the hard part. If you have a skid plate under the vehicle, remove it. Next, you will need to open the driver's side inner fender so you can see the starter. Make sure to disconnect the battery then you can work on it.
If you have any specific questions, let me know.
joe
Oct 2, 2008 at 3:52 AM
