1995 Dodge Colt coolant gauge
1995 DODGE COLT
188,880 MILES • 4 CYL • 2WD • AUTOMATIC
ROYBOY38
I have a 1995 doge colt gauge was only moving up to the cold mark and move back and forth. Thought maybe thermastate was bad it appeared to be when I took it out. I replaced the thermastate now the temp gauge does not move at all and check engine light came on I am getting heat the engine is a 1.5 I thinking maybe temp sensor
Jan 4, 2008 at 6:32 AM
  • 110,244 POSTS
Hi:
Yes, chances are it is the temp sensor. If you are getting good heat, you know the gauge is wrong.
Let me know if it helps.
Mar 10, 2009 at 3:21 AM
