2006 Dodge Charger thermastat
JESSEFEES
  • 2006 DODGE CHARGER
Engine Cooling problem
2006 Dodge Charger V8 Two Wheel Drive Automatic
how do you the thermastat
Thursday, December 25th, 2008 AT 12:18 PM
  • 109,885 POSTS
Hi:
Firt drain the radiator. Next, follow the upper hose to the engine. It will end at the t-stat housing. Remove the hose and the housing andthe t-stat is under it. Pay attention to the direction it is in so you can replace the new one the same.
Just reverse the order to replace it. Also, make sure to use the proper type of coolant.
Friday, March 6th, 2009 AT 7:17 PM
