Vacuum Leak
DODGE CARAVAN
DALLEN@GVISD.ORG
My 1998 Dodge Caravan 3.3 is idliing at nearly 2000rpm in park, aroung 1500 in drive and around 1000 if the air is on. The check engine light came ome andf the Codes were P0700 and P1294. I have checked out all the vacuum lines I can find and replaced mort of them but the issue presist. I am at a lost.
Oct 20, 2007 at 6:21 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
P0700= Transmission control malfunction
P1294= Iac needs to be checked...Idle air control valve, it's bolted to the side of the throttle body.
Oct 20, 2007 at 6:33 PM
