hesitation mostly between 38-50 MPH
DODGEDUDE
1997 Dodge Caravan, 4 Cyl. 150,000 miles. van hesitates/sputters when accelerating from a coast. mostly when accelerating (like going up a hill) at 38 mph through 50 mph. I changed plugs, gas filter (at the tank, which needed to be done anyway). still gets decent gas mileage. doesn't blow smoke. Doesn't stall or overheat. Thinking O2 sensor, which was replaced about 60,000 miles(approx. 3 1/2 yrs.) ago. Or possible vacuum leak? Starts every time, no problem. Does it no matter what the weather or driving conditions are. Any ideas? Also what is the procedure with turning the ignition on/off to get the codes? how do i do it? I appreciate your wisdom on this.
Mar 18, 2007 at 4:09 PM
KNIZET
Did you ever find out what was causing the problem? I have a similar problem with a 2005 Grand Caravan. It seems to be hesitating, bucking etc in high gear at about 40 mph under light engine load, like going up a low incline hill. I'd be interested to know how you resolved your problem.
Thanks
Apr 11, 2007 at 4:48 AM
