Electrical Problems
BITHEAD
2002 Grand Caravan Sport, 3.3L V6 w/ 57K miles. I have a few problems...
1) The front passenger window stops and starts working for no apparent reason. When not working, no "hum" or any other noise is heard -- it just doesn't move up or down.
2) Rear door on the driver's side -- the lock doesn't unlock/relock with the rest of the locks when using the lock/unlock buttons on the front doors, or when using the remote.
3) The (3 button) remote will only unlock the doors. I can't get it to lock them, and the Panic button does nothing. I have replaced the batteries to no avail.
I'm hoping there might be a common cause for all of the above? Any insights appreciated.
Sep 27, 2007 at 12:31 PM
BMRFIXIT
  • 19,053 POSTS
to answer your last question about common cause
will be NO
1- the front passenger window you 3 Possibilities
A: window motor ( you can pull the door panel and check the power and ground on the motor)
B: wiring ( twist the harness in the door jam while trying to work the window)
C: not likely but possible the switch
2: its the door lock actuator you need one
3: remote do you have a 2nd remote to try it and it my need to be programmed
good luck
let us know
have 3
Sep 27, 2007 at 1:41 PM
BITHEAD
Thanks for the reply. Here's what I know so far...
1) The dealer I bought the car from is going to have the window motor replaced.
2) The dealer will have a look at the door lock/actuator problem at the same time
3) Nope, no 2nd remote. I tried reprogramming as per instructions but it didn't help. Is my best option to replace the remote and have the new one programmed by the dealer?
Sep 28, 2007 at 8:45 AM
BITHEAD
Here are the resolutions to my issues...
* The dealer I bought the vehicle from replaced the window motor.
* The dealer I bought the vehicle from replaced the actuator.
* The dealer I bought the vehicle from reimbursed me for the cost of a new remote and the programming of it.
And I have to mention that I bought the vehicle AS-IS with NO WARRANTY, so the dealer did not have to do anything about any of the above problems. As far as used car lots go, I must say that Bridgeside Motors in Alameda, CA is a great place to buy a car! :D
Oct 4, 2007 at 8:45 AM
