1997 Dodge Caravan High Fuel Use
QUITOSKY
Hi, i just bought a used 97 caravan from a private owner. he gave all the maintainance records and the last time he had it tune up was last 2000. the van cosumes too much fuel. i put $20 and it only last 4days with about 10miles of travel a day. Caravan has 6cyl, 3.0 engine. if you could advice me what to do and recommend what kind of spark plugs and wires. i appreciate your input.
Mar 8, 2006 at 3:19 PM
JPAM
  • 307 POSTS
9.10 gallons of gas is a bit much for 40 miles.. Like you said start out with plugs, wires, cap and rotor.. Not to pricey to start off with.. Im thinking since u have a 3.0 it is a bit tight to work on.. It just might be that the plugs against the firewall might not have been change at the same time as front plugs... Lots of places when getting tune up wont change back plugs..just because their lazy.. well get to it.. and let us know thnks jess s.
Mar 10, 2006 at 2:56 PM
Suggested Repair
Start with a basic tune-up: replace the spark plugs, plug wires, distributor cap, and rotor. On the 3.0L, also check the rear plugs against the firewall, which are often left unchanged because they are hard to reach.
Conversation Summary
The owner of a used 1997 Dodge Caravan with a 3.0L 6-cylinder says it uses too much fuel; the last tune-up was in 2000, and about $20 of gas lasts four days at roughly 10 miles a day. The expert says that is high for about 40 miles and recommends starting with plugs, wires, cap, and rotor, noting the tight engine bay and that rear plugs are often skipped.
