2005 Dodge Caravan power outlets
54,000 MILES • 6 CYL • FWD • AUTOMATIC
HMHUBB
how do i make the power outlets on a grand caravan work without key being on?
Sep 8, 2008 at 1:44 PM
KEVIN12881
  • 336 POSTS
The one that is the ciggerette lighter should be a constant hot. If not the it may be easier to just put in a whole new one. you can buy one at advanced for little money. you will also need wire and an in line fuse. YOU NEED THE IN LINE FUSE AND A FUSE. never add anything electric without a fuse. Then if you can go through the fire wall from the battery that is fine, or maybe you can connect to the fuse panel inside the cab. I do not suggest haveing this power source you wish for. why do you need it?
Sep 8, 2008 at 1:54 PM
HMHUBB
I run li-po battery chargers for rc airplanes. At times I need more than 1 hot outlet. The manual say's all 3 can be made to stay hot without key on.
Sep 8, 2008 at 2:01 PM
