I need you to try something. What I want you to do is remove the belts from the engine. You may have 2 or only 1. Do this when the engine is cold. Start the engine without the belts, and see if the sound is gone.
NOTE: DO NOT RUN THE ENGINE FOR LONGER THAN 10 SECONDS. IT WILL OVERHEAT AND CAUSE NEW PROBLEMS FOR YOU. JUST RUN IT LONG ENOUGH TO SEE IF THE SOUND IS GONE.
Let me know what you find.
Oct 22, 2009 at 1:24 AM
