First off, thank you for the previous answer you gave on my van heating system. If helped out alot. Now I have had a check engine light appearing on the dash since I picked it up from the mechanic. He turned it off the next morning when I brought it back. The next day it came back on. The light stays on. Now yesterday I went to fill the tank I discovered the fuel cap was almost coming off of the fuel neck. Could this be my problem with the engine light or do I need to pull the code out of the computer? Do I need to have the light turned off or will it go off by itself?
Any help would be greatly appreciated. Jason
SPONSORED LINKS
Wednesday, January 30th, 2008 AT 10:46 AM
