2002 Dodge Caravan Blown spakr plug
KAA5092
  • 2002 DODGE CARAVAN
  • 4 CYL
  • 100,000 MILES
What would cause a spark plug to blow out of the engine? When my husband looked at it, the plugs looked old and crappy, but would that be the only reason? It actually left the threaded part in the engine. He is all freaked out now because it seems that we have had a rash of terrible luck lately with our vehicles.
Tuesday, July 6th, 2010 AT 7:07 AM
Hi kaa5092, Welcome to 2carpros and TY for the donation
Its probably loose and worked itself out if the threads are in good shape on the head-go ahead and replace the plug with the OEM part
Tuesday, July 6th, 2010 AT 10:36 AM
DOCFIXIT
  • 18,828 POSTS
Hi Plugs can fail and come apart like yours did. Alot to do with plug life now up to 100K miles. The constant shock of detonation and getting hot and cold over and over can cayse plug to come unsealed from base. Replace plugs and you will be good to go.
Hope this helps
Thanks for donate
Tuesday, July 6th, 2010 AT 10:37 AM
