2001 Dodge Caravan car willn't start
169,000 MILES • 6 CYL • 2WD • AUTOMATIC
STAKE9451
ignition key willn't turn to start car
Dec 1, 2008 at 11:14 PM
  • 110,251 POSTS
Hi:
What happens when you turn the key? Does the engine crank?
Dec 5, 2008 at 7:40 AM
STAKE9451
key willn't turn at all
Dec 7, 2008 at 2:37 PM
  • 110,251 POSTS
Hi:
If the key doesn't turn, there is a problem with the tumbler. Because the van has an airbag and the steering wheel will need removed, I recommend having it the work done by a trained technician. The air bag can be easily deployed if you are not trained to work with them. Then you're stuck with a larger bill.
Dec 8, 2008 at 2:23 AM
