2001 Dodge Caravan
JASON76
  • 2001 DODGE CARAVAN
Heater problem
2001 Dodge Caravan
With heater on, driver's side heat blows out just fine but passenger side is cold. The van has seperate controls for driver and passenger but passenger also includes back air and its hot too just front passenger air is cold. Hope you can help.
Friday, February 26th, 2010 AT 7:26 AM
  • 110,182 POSTS
I think you are looking for a vacuum leak in this case. The vent doors are actuated by vacuum. If there is a leak, the heat may not get directed to all locations. Check under the dash for leaks and check the linkage going to the actuators to make sure nothing is disconnected.
Let me know what you find.
Wednesday, March 3rd, 2010 AT 10:42 PM
