2000 Dodge Caravan stalls when put in gear
SIERRA064
  • 2000 DODGE CARAVAN
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic
2000 Dodge Caravan starts and runs fine put it in gear and it dies, had a trouble for an EGR valve put on a new EGR valve cleared the code and still same problem any ideas
Monday, March 15th, 2010 AT 6:01 PM
LEGITIMATE007
  • 5,121 POSTS
Check the torque convertor clutch solenoid.
Monday, March 15th, 2010 AT 7:28 PM
LEGITIMATE007
  • 5,121 POSTS
Is there a check engine light on
Monday, March 15th, 2010 AT 7:29 PM
SIERRA064
How would I check that I can not find that in my book and yes the Check Engine Light is on but I do not have a scanner but will go get one soon and find out what code has been set
Tuesday, March 16th, 2010 AT 3:42 PM
SIERRA064
The light was on for the TPS but I had been testing that cleared the code now I have no codes but it still stalls when put in gear
Tuesday, March 16th, 2010 AT 7:26 PM
LEGITIMATE007
  • 5,121 POSTS
You can go ahead and clean the egr valve as this is a possibility, but I also need to know what size engine is your vehicle? 3.0, 3.3, or 3.8. Also the vehicle need to be scanned, it will make it sooo much easier.
Wednesday, March 17th, 2010 AT 7:13 AM
SIERRA064
I repaced the EGR valve and cleard all the codes but still have the problem that it stalls when I put it in gear, it dose sound like it maybe the torque convertor clutch solenoid but I dont know how to test it or where it is on the transmission. It has the 3.3L V6 with the G vin for the engine.
Wednesday, March 17th, 2010 AT 12:29 PM
LEGITIMATE007
  • 5,121 POSTS
Well its coming up as transmission control solenoid and all it says is its located on the transmission, its a plug obviously, and there are three or four. It says this vehicle doesnt have a torque convertor clutch solenoid, they are control solenoids. It would really help if we could get this thing scanned again
Wednesday, March 17th, 2010 AT 12:56 PM
