Brakes problem
2000 Dodge Caravan Engine Size unknown Front Wheel Drive Automatic 100646 miles
What is the process of changeing the rear brakes.
my engine size is 3.5.
Wednesday, January 9th, 2008 AT 6:06 PM
SERVICE WRITER
MECHANIC
You'll need to machine or replace the drums.
There area series of springs that need to be removed. Some are hold down springs others are return springs. There is an adjuster that needs to be reomoved, separated cleaned and lubed before re-installing. On the backing plate there are raised areas that the shoes set and slide on, these needs to be cleaned and lubed. May want to pick up a manual:http://www.2carpros.com/kpages/auto_repair_manuals.htm
