2000 Dodge Caravan Fuses
MIDORI11
2000 Dodge Caravan
The horn in our van no longer works, I've checked the fuses under the hood and the dash. What else can I do ? Also our rear wing window and airbag light came on. Is there a fuse the effects all three?
Feb 21, 2009 at 4:20 AM
JDL
  • 16,098 POSTS
Hello, not only check the fuse, check that the fuse circuit is hot, use test lite.
You can do testing at the horn relay in the power distribution center, under the hood. Just unplug the relay, use a testlite, two terminals hot. If that checks out, there may be a problem with the clock-spring in the steering column? If there is an airbag in the steering wheel, there may be a safety issue.
Feb 21, 2009 at 5:34 AM
