On this vehicle in order to replace the water pump, the timing belt needs to be removed.
After removing the drive belt you will have to remove the timing belt cover and the timing belt.
Always remember to mark and note / take pictures of the timing belt marking. It is critical that the belt goes is exactly same orientation of all the pulleys. I have included the timing belt removal and installation as well as the water pump instructions (look below).
Remember to work on the vehicle when the engine is cold.
https://www.2carpros.com/articles/water-pump
https://www.2carpros.com/articles/water-pump-replacement
https://www.2carpros.com/articles/how-a-timing-belt-works
SPONSORED LINKS
Friday, August 13th, 2021 AT 8:45 PM
