1999 Dodge Caravan Failed Smog Test
ELGRANRUDO
Other Category problem
1999 Dodge Caravan Engine Size unknown Wheel Drive Type unknown Automatic 180000 miles
My van failed its Smog Test because the "check engine light" even though it was not on had yet to reset itself after I changed the battery. But the strange thing is I changed the battery over one month ago and have put in over a thousand miles since. How can I correct this?
Jan 5, 2008 at 5:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4d61270559="ElGranRudo"]Other Category problem
My van failed its Smog Test because the "check engine light" even though it was not on had yet to reset itself after I changed the battery. But the strange thing is I changed the battery over one month ago and have put in over a thousand miles since. How can I correct this?[/quote:4d61270559]
what is the codes
repot should give you reason to fail
Jan 5, 2008 at 8:00 AM
