1999 Dodge Caravan
CHRISMITH
  • 1999 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 126,000 MILES
How do I replace rear wheel speed sensor on my 1999 dodge caravan.
Saturday, December 29th, 2007 AT 2:17 PM
MERLIN2021
  • 17,250 POSTS
The reason you want to do this is? Use an ohm meter on the end leads, if your reading is 800-1400ohms the sensor is OK. If you have an ABS code, what is it> If you still want to change it 1 bolt usually holds them on, but they tend to stick in the hole! If you are changing it, tat it out with a punch, dont hit the exciter ring, it's magnetized!
Sunday, February 21st, 2021 AT 1:01 PM
Related ABS Wheel Speed Sensor Replace/Remove Content
