HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Overheat
1999 Dodge Caravan
GOBLUES1269
MEMBER
1999 DODGE CARAVAN
Engine Cooling problem
1999 Dodge Caravan 6 cyl
my van overheats and the ac goes warm at the same time, what could be causing it?
Tuesday, June 2nd, 2009 AT 6:55 PM
F4I_GUY
MECHANIC
Stuck thermostat, weak radiator, loss of coolant caused by an external or internal leak, failed water pump, failed headgasket.
Check the basics first. Check to make sure there is coolant in the resevoir and tank.
SPONSORED LINKS
Tuesday, June 2nd, 2009 AT 7:11 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Overheating Issue
Engine Cooling Problem 6 Cyl Front Wheel Drive Automatic 120, 00 Miles My Van Was Overheating, I Took It In And Had My Radiator Flushed...
Asked by
mark4613
1 IMAGE
1999
DODGE CARAVAN
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1999 Dodge Caravan Over Heating
A Radiator Hose Was Replaced A Few Months Ago And Fixed That Problem At That Time But After That I Am Assuming Another Problem Arose Because...
Asked by
natkat333
1999
DODGE CARAVAN
Van Overheating
I Have A 1998 Dodge Caravan That Keeps Overheating No Other Symptoms Flushed Radiator And Changed Thermostat Already Any Ideas? Also Can Van...
Asked by
lilb72714
1998
DODGE CARAVAN
Engine Overheating
Engine Cooling Problem 6 Cyl Two Wheel Drive Automatic 99046 Miles My Car Out Of The Blue Started Overheating. I Had The Thermostat...
Asked by
kristi_m_neal
1 IMAGE
2002
DODGE CARAVAN
Engine Overheated Now Heater Blowing Cold
When I Talked About The Parts Replaced I Said The Thermostat. But The Engine Temp Hand Still Falls To The Left. I Bought A New Thermostat...
Asked by
junk.man
1996
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Online car repair manuals
