1999 Dodge Caravan
KATHY4912
  • 1999 DODGE CARAVAN
  • 6 CYL
  • 110,000 MILES
No power goes to the engine from the ignition switch. `The electrical panel works. The battery is working the fuses were checked. Does the engine have a kill switch that stop the ignition switch to start the van.
Wednesday, January 16th, 2008 AT 10:46 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to be more specific. Does it not crank?Crank and not start?
Thursday, January 17th, 2008 AT 7:33 AM
KATHY4912
  • 5 POSTS
It does not crank nor does it start. It looks like the ignition switch does not send power to the starter.
Thursday, January 17th, 2008 AT 12:37 PM
2CARPRO JACK
  • 11,533 POSTS
Find the starter and test the small wire for 12 volts with key in crank position. Does it have an aftermarket alarm system?
Thursday, January 17th, 2008 AT 12:42 PM
KATHY4912
  • 5 POSTS
Thursday, January 17th, 2008 AT 12:54 PM
KATHY4912
  • 5 POSTS
[/quote:ebf8b67df6]we try already. Ithe starter is working find. No power is leaving the ignition switch to crank the engine. The fuses were also checked. Could it be an electrical switch that killed the the power to the engine.
Thursday, January 17th, 2008 AT 12:58 PM
2CARPRO JACK
  • 11,533 POSTS
You will need a test light. Under dash/column wiring check the big yellow wire out of the ignition switch for 12 volts in crank position. If none then ign switch is probably bad, if it has power, go to underhood relay center and unplug the starter relay. Conn #86 shoul dbe power in crank position, #30 is power, #85 should be ground when key in crank position. If no power at #30, check fuse #23. Does this van have an aftermarket alarm?
Thursday, January 17th, 2008 AT 1:59 PM
