1998 Dodge Caravan possible fuse
170,000 MILES • V8 • FWD • AUTOMATIC
KIMWADDELL
All gages on the dash froze. I don't know where the fuses are located. Could it be something different. The car still runs fine.
Oct 30, 2008 at 6:17 AM
  • 110,245 POSTS
Hi:
When you say all the gauges froze, do you mean they have returned to their start position and no longer work or did they freeze at the position they were in when you were driving?
What to do is check the fuses (driver's side under dash). If they are ok, with a flash light, check under the dash (toward the insturment panel) for loose connections or broken wires. If you find nothing, you may need to have the BCM checked.
Let me know what you find.
Oct 30, 2008 at 6:38 AM
