HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Fuel System
Fuel Pump
Fuel Pressure
SPONSORED LINKS
1998 Dodge Caravan Fuel pump
BALDYSBUILDERS
MEMBER
1998 DODGE CARAVAN
Engine Mechanical problem
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have no fuel pressure and have changed two fuel pumps. Code from dash is 12543155? Any help
Saturday, January 10th, 2009 AT 10:02 AM
BMRFIXIT
MECHANIC
Check fuses relays and wiring
with key 1st on u should have battery power at the pump and if so check for ground
as for the code u given its more like mileage then a code
to get the codes cycle ignition on off on off on
read P codes in the odometer area
it will say P0000 and then DONE
SPONSORED LINKS
Saturday, January 10th, 2009 AT 2:34 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Fuel Pressure Content
No Start, Has Fuel Pressure But Not Spark
Replaced Coil Pack, Cam Sensor, And Ecm. Has Fuel Pressure, No Spark. Relays Fuses All Good. When Turn On Key There Is A Click Under Dash...
Asked by
Johnnie Arthur
1999
DODGE CARAVAN
1993 Dodge Caravan Gas Mileage
Getting Less Gas Mileage After New Fuel Pump Installed Replaved Fuel Pressure Reg. There Are New Wires, Pluga, Air Filter And Throttle Body...
Asked by
2cherokees
1993
DODGE CARAVAN
2000 Dodge Caravan Fuel Issue
I Had A Mechanic Hookup A Fuel Pressure Tester To The Fuel Line, Started The Van Up An It Read Around 50 Psi The Needle Was Shaking Side To...
Asked by
baconeggs22
2000
DODGE CARAVAN
1994 Dodge Caravan Power To Fuel Pump
I Had To Slam On The Brakes In Traffic, The Engine Stalled And Never Restarted. There Is No Fuel Pressure At The Fuel Rail. The Pump Is...
Asked by
Bob Yaras
1 ANSWER
1994
DODGE CARAVAN
1991 Dodge Caravan
Engine Performance Problem 1991 Dodge Caravan 4 Cyl Front Wheel Drive Automatic I Bought This Caravan For Cheap, Because It Would...
Asked by
Caliber51
1 ANSWER
1991
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Fuel Pump Replacement
How to fix an engine that wont start
Fuel Pump Pressure Test
Online car repair manuals
