1998 Dodge Caravan AC doesn't work anymore
176,000 MILES • 4 CYL • 2WD • AUTOMATIC
JHARB52207
  • 5 POSTS
Hi there. AC stopped blowing cold last week. I checked the low side and it was down pretty far. After I filled it back up I heard a hissing sould (engine was off at this point). After some hunting I found the noise on the high side valve and had to tighten it. By that time most of what I had put in came out. After filling it back up again and insuring no leak this time the AC was still hot. I also have my rec air and ac lights blinking at me. I looked around on the net and found the retest procedure but that is not stopping the blinking. What next?
Jun 20, 2008 at 8:09 AM
DOCFIXIT
  • 18,828 POSTS
What were the readings I need high and low compressor running.
Let me know
Jun 20, 2008 at 8:23 AM
JHARB52207
  • 5 POSTS
When I started it was all most 0 psi, I filled it to 35 psi
Jun 20, 2008 at 8:46 AM
DOCFIXIT
  • 18,828 POSTS
Must have high side reading
Jun 20, 2008 at 9:22 AM
JHARB52207
  • 5 POSTS
Ok how would I do that. All I bought was one of those cheap cans of 134 with a pressure gauge? This is a new area for me, just a computer guy.
Jun 20, 2008 at 9:26 AM
JHARB52207
  • 5 POSTS
I didn't notice the high side leak until after I had filled the low side up, the low side was just about 0 when I started. It leaked for about 5 mins before I could nail it down to that value. Since I tightened it the leak is gone, but I can see the need for a reading. What should I get for that?
Jun 20, 2008 at 9:41 AM
DOCFIXIT
  • 18,828 POSTS
THis is work better done by a trained professional.
Sorry you should take this to a shop.
Jun 20, 2008 at 10:35 AM
JHARB52207
  • 5 POSTS
Ok will do thanks
Jun 20, 2008 at 10:36 AM
