I have a 1997 caravan and the tranny went into limp mode. I recently learned that since I rarely use it, the battery drains which is why I have had to jump it when i use it once a month or so. My speedo and tach work fine but the traction control button is stuck in (track off) I definately think the tranny issue has to do with the battery dying and not a bad tranny, but I do not know what to do to resolve it. what is the issue most likely to be, If it is a solenoid or the tranny computer which would it most likely be, or is it to do with the wire from the tranny to the battery cable?
Their has to be a simple common cause here that relates to limp mode after a battery dies or after it gets jump started.
something commonly happens in these vehicles that puts it into limp mode when the battery drains or when the battery gets jumped? Their has to be a common cause or solution for this popular occurence?
Jun 27, 2010 at 8:47 PM
