1997 Dodge Caravan jump to start
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
MADDIE24
my van will only start if i jump it but my battery is new and it is not loosing the charge. i thought it might be the alternator but i have confirmed the battery is not being drained by putting the battery in another car and it starting right up without a jump.
Jan 9, 2010 at 1:58 AM
  • 110,245 POSTS
If your battery is good, make sure the terminals are clean and tight. Somewhere you are loosing power from your battery and when you jump it, you connect right to the terminals, so the break down has to be there.
Let me know. Also, check the ground to the engine block to make sure it is clean and tight too.
Jan 10, 2010 at 3:21 PM
