security light?
1997 DODGE CARAVAN
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
MBEER5
I have a 1997 Caravan with 120000 miles. When I start it, it sometimes runs for 3-5 seconds then shuts down. I noticed that the "Alarm Set" indicator in the dash will sometimes start flashing when driving and just before the starting problem shows up. Could it be a problem with the factory alarm system shutting down the engine? I also need to know where to look for the Valet switch for the alarm so I can switch it and see if that makes a difference.
Dec 26, 2008 at 12:40 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Hi:
it sounds like a problem with the security system. To determine the problem, you need to take it to a dealer where they have the proper test equipment to check the system.
Dec 26, 2008 at 10:57 AM
