1996 Dodge Caravan Sporatic hesitation
BUBBLY12
  • 1996 DODGE CARAVAN
  • 4 CYL
  • FWD
  • 12,800 MILES
Sporatically while driving at a constant rate of speed around 60 mph the engine hesitates for a second or so before resuming the speed. There are no problems recorded on the computer or on the code recorder. I have recently changed: catalytic convertor, spark plugs, spark plug wires, coil, and fuel filter.
Thursday, October 7th, 2010 AT 10:08 AM
Lack of acceleration, chugging, hesitating, jerking, bogging, misfiring etc. Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Thursday, October 7th, 2010 AT 6:53 PM
