1996 Dodge Caravan Recieved trouble codes P0500;P0720; and
120,000 MILES • 6 CYL • FWD • AUTOMATIC
KIDTAU
Just had transmission serviced for over $ 1,000. These trouble codes showed up on code reader..please advised..have had car only back for two days..
Dec 24, 2008 at 1:54 PM
ZACKMAN
  • 4,202 POSTS
P0720 Output Speed Sensor Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
What does that mean?
Basically this means that the vehicle's speed as read by the Vehicle Speed Sensor (VSS) is not working properly.
Symptoms may include:
* loss of anti-lock brakes
* the "anti-lock" or "brake" warning lamps on the dash may be lit
* the speedometer or odometer may not work properly (or at all)
* your vehicle's RPM limiter may be decreased
* the shifting of an automatic transmission may become erratic
* other symptoms may also be present
Causes
A code P0500 may mean that one or more of the following has happened:
* The Vehicle Speed Sensor (VSS) is not reading (functioning) properly
* There is a broken/frayed wire leading to the vehicle speed sensor
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back.
Next, check all wiring and connectors that lead to the speed sensor. The location of the sensor depends on your vehicle. The sensor could be on the rear axle, transmission, or perhaps the wheel hub (brake) assembly.
If the wiring and connectors are OK, then check the voltage at the speed sensor. Again, the exact procedure will depend on your make and model of vehicle.
If everything looks OK, replace the sensor.
***If the transmission was just serviced, then they didn't do the job right. Tell them to fix it, but I won't pay them any more money...
Dec 24, 2008 at 2:41 PM
