1996 Dodge Caravan power brake booster removal.
1996 DODGE CARAVAN
WARMUTT
Brakes problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
i have removed everything short of removing the engine itself. i have removed the four bolts holding the power brake booster and all hoses and master cylinder from the brake booster but it still refuses to come out. i also disconnected the linkage to the brake pedal. is there a trick to loosening the booster? i am layed off currently as are many americans and cant safford to take this problem to a certified mechanic.
Sep 11, 2009 at 2:26 PM
DOCFIXIT
  • 18,828 POSTS
Hi
ABS brakes? Was CAB removed? took off four nuts below dash by pedal? if yes it is stuck on hanging up on studs. Use the handle of a hammer to tap on studs. if it loosens pull booster up and towards engine.
Hope this helps
Thanks for donate
Feb 25, 2021 at 8:34 AM
