1995 Dodge Caravan engine light
11,700 MILES • 6 CYL • FWD • AUTOMATIC
MIKEYDOGA
check engine light wont come on when you turn on ignition-they wont give me my smog certificate even though it passed i changed what i think is the right bulb i guess i need to know which is the check engine light on the dash and which fuse and relay control it please help i cant get book from the library to findout or find the info. please and thanks for any help you can give me signed gratefull
Nov 3, 2009 at 6:11 AM
CH112063
  • 1,320 POSTS
Glad it is not just 'on' all the time. The computer, is probably fine. Do the lamps in your instruement panel work at all?
It uses a small bulb that sometimes burns out. The bulbs near it, if lit, will fit in. And if they are ok, swap em and buy a new bulb. There is a power center under the hood that has engine control fuses. I have not had to replace the computer for this problem except twice. Out of dozens.
What do you need to know? do you have a way to test for 12 volts? The socket connectors went bad all the time. Electronic digital dash?
Nov 3, 2009 at 1:06 PM
