1993 Dodge Caravan
CHEVYMAN-74
  • 1993 DODGE CARAVAN
Engine Mechanical problem
1993 Dodge Caravan 4 cyl Front Wheel Drive Automatic
i have a 93 dodge caravan with a 2.5 4cyl. I replaced the comp. The prob is it wont start. Its not getting fire to the coil, or any where else. The only thing that comes on is the fan. Where do I start?
Tuesday, July 27th, 2010 AT 1:27 PM
  • 109,755 POSTS
Hi:
I need some info. What was the vehicle doing prior to the computer's replacement? Also, have you checked all the pins in the wiring harness to make sure none are bent, pushed, or corroded? Finally, are you getting fuel pressure (is the pump running)?
Tuesday, July 27th, 2010 AT 9:24 PM
