1992 Dodge Caravan rollover inleft hand turns
1992 DODGE CARAVAN
288,808 MILES • 6 CYL • FWD • AUTOMATIC
ZEFFMORENO
hi my question is when ever i take a left hand turn it seems that the right side of my van leans too much to right. it acts as if i were turning left up a hill and i have to correct my steering quickly .what could cause this i replaced the following lower ball joint , right outer tie rod end, sway bar bushing and right c.v. shaft i don`t know what else to do, i have done the repairs my self and thought i did the job right but i have no clue why the steering get goofed up when i turn left.help!
Oct 7, 2008 at 1:53 PM
RWM
You need to have your steering aligned. When you repaired the front end on your car, you got the camber and caster out of adjustment. It needs to be aligned with special equipment as there are many adjustments that can be mode other than toe in or toe out.
Jan 15, 2009 at 12:10 PM
