1992 Dodge Caravan fusible link?
1992 DODGE CARAVAN
HOOPTIE
Electrical problem
1992 Dodge Caravan 3.2 miles
my battery gets discharged when my vehicle is turned off.I can tell that something is on when I hook and unhook my battery to preserve my battery power.What size is the wire to the harness to the (pos)battery post?
Dec 18, 2007 at 3:39 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Get an analog voltmeter remove the negative battery cable, attach the red lead to the battery post, black lead to cable end, then pull fuses one at a time, make sure there are no accessories or lights in the on position, Key off! Close the door after each fuse and check meter, when you pull the fuse for the bad curcuit, the meter will drop to 1 volt or so. Check all fuses, even under the hood. If meter does not drop, remove the battery connection from the alternator, if it drops now, the diodes are bad in the alternator. Put the fuse back in were it goes as you go so you don't forget which fuse goes were!
ALWAYS dissconnect the NEGATIVE cable(-) FIRST and hook it up LAST! BTW It's 4 guage cable...
Dec 18, 2007 at 5:22 PM
