1999 Dodge Avenger Water Leaking!
77,800 MILES • 6 CYL • FWD • AUTOMATIC
EMMONSJA0687
OK i have noticed that when it rains my passenger side gets soaked with water on the seat and the floor..also i have a sun roof..and when i stop..water starts to drip near the sunroof swith and interior lights on the cieling..i cant figure out where the leak in coming from. i noticed taht some water builds up around the sunroof..but i cant find the drain anywhere..this is really becoming a problem and with the spring rain comming up..i dont want to have to deal with this every time it rains..any ideas? or any places that i can take it to get fixed?
Feb 27, 2009 at 6:28 AM
MERLIN2021
  • 17,250 POSTS
The roof does have drains, and usall the rear drains are in the rear wheel wells, try short blasts of compressed air to clear the drains, one thing you should know, the tubes can come off using this method, then you would need to remove the headliner to fix it, but you may need to do that anyway, other areas water gets in, At the "A" pillar, around the sides of the windshield, use either butyl, or RTV and apply it there. If the windshield has a rubber piece attached to it, lift it and apply sealant under it.
Feb 27, 2009 at 6:34 AM
