1998 Dodge Avenger transmission leak
110,000 MILES • 6 CYL • FWD • AUTOMATIC
ALIEN0113
I discovered a major leak coming from the transmission bellhousing. I dropped the trans and replaced the pump shaft seal and reinstalled the trans, once i started the car and put into gear it started pouring trans fluid out again. I dropped and inspected seal, but looks good, and torque convertor looks good. what am i missing?
Apr 1, 2010 at 8:07 AM
2CARPRO JACK
  • 11,533 POSTS
May be the outer pump seal (O'ring) this is one that a trans shop should replace, it requires a puller and may also nee to remove the pan.Call a few trans shops and ask how much to reseal it on the bench, so you can do the expensive part (removal and replacement)
Apr 3, 2010 at 2:11 AM
