1998 Dodge Avenger Stalling
TABBYCARROLL
  • 1998 DODGE AVENGER
  • 6 CYL
  • 120,000 MILES
My car has an off and on problem that is getting worse. When running it runs great. While driving even on the highway the car stalls. When it does stall it wont start again until after it sits for a while (more than an hour) We hooked a scanner up and all it said was egr valve (though we knew it wasnt the reason we fixed it) The we checked the fuses and engine compression both good as ever, checked the ignition system for any defects or moisture and nothing. When trying to start the car after it stalls, it tries really hard like it has plenty of power but nothing. Its got power and a good spark I just dont know what it wrong with it. Please help me figure out what is wrong!
Friday, January 4th, 2008 AT 8:31 PM
BRUCEBRUCE16
  • 6 POSTS
I also have the same 2000 dodge avenger I took it in for the same problem and they told me it was the fuel pump and fuel injectors but once I fixed them the car still acted up the same way but the job cost $500 maybe it will work for you I doubt it though try taking it to a certified michanic for a complete diagnostic im doing that tomorrow ill let you know what they say
Monday, March 10th, 2008 AT 12:01 AM
ANGELBABY19491983
It is your crankshaft precision sensor! I have a 1996 Dodge Avenger ES and mine also was doing that and my friend told me it was that sensor so I changed it and it does not do that any more! Hope you get it fixed they are great cars !
Monday, April 28th, 2008 AT 8:20 PM
Related Engine Stall While Driving Content
Code Read Retrieval/Clear - Dodge Stratus
VIDEO
