1996 Dodge Avenger 96 avenger
BILL2979
Engine Performance problem
1996 Dodge Avenger 6 cyl Front Wheel Drive Automatic
the car bucks when u drive it and when you come to a stop it stalls . i had it scanned and it sead bank 1 to rich .i chaned o2 sensers and map to it fixed the proble for a few miles and no its doing the some thing .its a dodge so i turn the key on off on off on and count the blinks it comes up 12 13 and 55 .i think the ecu is starting to go but im not sure .can you tell me what these codes are
Nov 21, 2008 at 1:21 PM
ZACKMAN
  • 4,202 POSTS
12 - Problem with battery connection. Direct battery input to PCM disconnected within the last 50 ignition key-on cycles.
13 - Problem with MAP sensor circuit.
55 - Completion of fault codes display on CEL. This is the end of stored codes.
Nov 24, 2008 at 3:52 PM
