Diesel 15W-40 oil in an unleaded engine
2003 MAZDA 323
125,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
LABHAMSTER2
Recently had to add some oil to my car on a road trip, and the only 15W-40 available was a heavy duty diesel oil (Shell Rimula R4 L 15W-40 to be specific). Is it safe to keep using the engine for another week with this oil in it, or should I dump it and change over now?
Oct 10, 2020 at 11:53 AM
No. I would change it out. This oil is clearly not meant for your engine and the longer it is in there, the more potential damage is done to the bearings. Clearly it is not dire at this point unless you used more then 1 quart. How much did you add to the engine?
It is one thing to add a thicker oil but to add an oil for a diesel engine is just not going to help so the longer it is in there the worse it could be. So no matter what, I would just be on the safe side and change it as soon as possible.
Oct 10, 2020 at 11:59 AM
  • 110,240 POSTS
I agree with KaseKenny. A diesel engine oils will have a higher anti-wear design. As a result, different components are added to them in the form of zinc dialkyldithiophosphate. A catalytic converter in diesel system is designed to deal with this added component. A catalytic converter in a gas engine is not designed for it and it can cause damage to it.
As he mentioned, do it at the earliest convenience.
Oct 10, 2020 at 12:19 PM
