Need to change the bar that my wheel bearings sits on
2007 DODGE DAYTONA
123,456 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
ROBERT GLEBA
It has two wheel bearings in the front one in the back and one in the front. I need the bar that connects to them with the boots on them. The rubber boot on the backside of the bearing is blown and I want to replace that bar but I don't know what it's called.
Apr 26, 2019 at 7:01 AM
Hi Robert,
Can you clarify what kind of vehicle this is? Is it a Dodge Charger Daytona or is a Dodge Dakota?
Also, can you take a picture of the part you are describing and attach it? I am very familiar with these vehicles so I know I can identify what you are working with but just need to see it. A picture is work a thousand words because from what you describe it sounds like it is the axle shaft but I want to make sure.
Just get a picture of the overall assembly and then one of the actual component that you are looking for. Thanks
Apr 26, 2019 at 11:40 AM
