Dead Battery, Jump start didn't work
150,000 MILES • RWD • MANUAL
DSHABBIT
I recently left the parking lights on in my car over night, and when I attempted to start it the next day the battery was dead. When we connected jumper cables to the battery for a jump start, the light inside the trunk lit up. When I turned the key forward (not all the way) all of the dashboard lights came on like they normally do. But when I turned it all the way forward to start it, everything switched off and the engine gave no signs of even beginning to turn over. Since then, the car still won't start, and subsequent attempts to jump it haven't even gotten the lights to turn on in the same way.
Dec 20, 2014 at 5:55 AM
CARADIODOC
  • 34,414 POSTS
It sounds like you had bad connections on the jumper cable clamps. That is pretty common. Also, it takes a good 15 minutes for a totally dead battery to START taking a charge. Given the age of your car, (I drive an '88 minivan), you don't have to worry about computers needing to be unlocked by the dealer. Put a small portable battery charger on the battery and charge it for a couple of hours on the lowest setting, typically around 6 to 10 amps. If you still have trouble, check the battery cable clamps for corrosion and tightness.
Dec 20, 2014 at 6:53 AM
