I have a parasitic draw, pull all the fuses still test lead does not go out?
May 27, 2020 at 1:06 AM
✓Experienced Mechanic
Can you clarify this a little more? What do you mean the test lead doesn't go out? Do you have a test light hooked up to the negative terminal? Can you get a picture of the meter or leads you are talking about?
