Daytime Running Light
2006 CHEVROLET MALIBU
110,000 MILES
SIYAT
I have a problem that I'm trying to figure out. Forgive me for not being automotive inclined. I have a 2006 Chevy Malibu LS that is having an issue with the left side daytime running light. When I turn the key to aux power, the light turns on; however, when I start the engine, the driver-side light shuts off. I know it's not the bulb because of it. Also, because the light turns on with aux power, I know that it is receiving power. I would really like to attempt to take care of this but I'm not sure if there is something more major causing this problem.
Some other information, the car has a check engine light that is on. This may or may not be caused from this. I also don't know if this information will be needed but the Malibu's fuel gauge also repeatedly goes from full tank to empty and isn't an indicator of the actual fuel level. Again, not necessarily related, but thought I should mention it.
May 9, 2013 at 12:36 AM
we need the code for the light.
sounds like the sender in the tank for the fuel gauge
as far as fog light, could be either the headlight switch or the body control module
May 9, 2013 at 10:56 AM
