dash lights
2009 NISSAN NAVARA
80,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
TURNS
  • 5 POSTS
Hello, I have a Nissan Navara d40 and only recently had my parking brake light, battery light and my airbag light blinking on and off and today the abs light came on. I stopped and couldn't start it again as it drained the battery. My friend tried to use a diagnostic, but no faults codes.
Mar 4, 2016 at 5:18 PM
WRENCHTECH
  • 20,761 POSTS
The first thing to do is charge and test the battery and once you have a confirmed good battery, have the charging system tested.
Mar 4, 2016 at 10:12 PM
TURNS
  • 5 POSTS
Have a new battery lights still on.
Mar 6, 2016 at 12:52 AM
WRENCHTECH
  • 20,761 POSTS
The battery light is NOT an indication of a bad battery. It indicates the battery is not being recharged.
Mar 6, 2016 at 12:55 AM
TURNS
  • 5 POSTS
I understand as the battery drained . So you think it could be alternator or voltage regulator not allowing the battery to recharge? I'm only asking as I do not have a way to test it. If I can get a rough idea then I can see if my warranty will cover it.
Mar 6, 2016 at 1:01 AM
WRENCHTECH
  • 20,761 POSTS
That's not a vehicle we have in the US, but most vehicles have the regulator built into the alternator anyway. You need to do some testing before assuming the alternator is bad simply because a light is on.
Mar 6, 2016 at 1:05 AM
TURNS
  • 5 POSTS
OK mate I'm an Aussie . just a little stumped as I checked all my fuses and connections and tried a different battery
Mar 6, 2016 at 1:10 AM
  • 55,433 POSTS
Yes, it sounds like you have an alternator charge problem, here is a guide to help.
Please let me know how it goes
Mar 11, 2016 at 12:14 PM
